I hope you can answer my problem...
I have in my project a SNMP manager with -num 4.
I created just one SNMP agent with the System Management panel. (SNMP Manager 4 and Agent number 1)
I created a DPT with a Master Datapoint and some DPE with an _address PowerConfig to get some values from the agent.
When I start my SNMP Manager in the console, I get this ********** Warning in the Log Viewer :
[i]WCCOAsnmp (4), 2014.07.09 14:29:37.722, PARAM,WARNING, 54, Unexpected state, SNMPSrvHdl, singleQuery, agent ID 1 is not configured correctly - check configuration in DP and template DP![/i]Did anyone already have this problem before or know the solution ?
Thank you,
Jérémy Fily
PS: I attached an image for you to see the config.
EDIT :
