Dear All,
I need to set a value in the archive with _online_bad attribute set. I am trying to set the attribute but it is not set in the archive.
dpSet("System1:A_1.value.MW1:_original.._value", 0,
"System1:A_1.value.MW1:_original.._exp_default", true);
If anything needs to be done apart from this please let me know.
Thanks in advance.
Raj
Setting _online_bad attribute for a datapoint
- rajkumar.krishnan
Re: Setting _online_bad attribute for a datapoint
in your script you are setting the _attribute _exp_default which is the information that the _default-value shall be used. To set a original-value invalid you have to use the attribute _exp_inv.
- rajkumar.krishnan
Thany you it worked...
