Launching WCCOAUI.exe without log viewer
rajkumar.krishnan
Post by rajkumar.krishnan »
I am launching the WINCCOA UI exe with the below options to disable the log viewer.
WCCOAUI.exe -console -log[-]
But still it launches the log viewer. Is it i am giving wrong command line arguments or something else needs to be done.
Thanks in advance
Raj
Re: Launching WCCOAUI.exe without log viewer
the -log option is a standard option for every WinCC OA process to redirect the log-output and is not an option to define if the log-viewer shall be opened or not.
When opening the console panel it automatically shows the log viewer for the current project.
Why do you want to open the console without the logviewer?
rajkumar.krishnan
Hello Leopold,
We would like to give option to the that it should not open by default if user needs he can enable it.
Raj
funkey
Post by funkey »
I always start my projects like this without console and without log viewer:
"C:\\Siemens\\Automation\\WinCC_OA\\3.11\\bin\\WCCOAui.exe -PROJ project_name -p vision/login.pnl -graphicssystem raster -style plastique"
Just a small hint: -graphicssystem raster is not needed on windoze, since it's the only possibility there.
(Also on Linux since Qt version 4.8 -graphicssystem raster is the default)
