Our application has a requirement to retrieve the value of an archived Data Point Element at a single, specified time in the past.
For example, a DPE may have the following values recorded in the Event archive:
Time Value
2014.06.05 02:54:00.000 132.4
2014.06.05 04:12:00.000 189.0
2014.06.05 08:38:00.000 204.2
... and we may need to know what the value of the DPE was at 2014.06.05 06:00:00.000.
Currently, the only way I can get the value at 06:00 is something like the dpQuery:
SELECT '_original..value' FROM '{DPE}' TIMERANGE ("2014.06.05 06:00:00.000", "2014.06.05 06:00:00.001", 1, 1)
... and then figuring out what the value would have been at exactly 06:00 from the result set. The result set could contain 0, 1, 2, 3 or possibly more records.
Is there an easier way?
How to query the historical value of a DPE at a single, specified time in the past
- MartinBoers
Re: How to query the historical value of a DPE at a single, specified time in the past
yes, there is an easier way.
You can use the function dpGetAsynch() to get the value for a specific time. A documentation for this function can be found in the online help.
When reading historical values normally the config _offline is read instead of _original. This is necessary to get the correct value. The value for _original.._value, _online.._value and _offline.._value can be different if a _default-value or a correction value is set.
For detailed information please have a look at
