Hello!
Is it possible to run a script of another object directly? Name of the object known. For example - run MouseHover event script.
Will I use this?
getValue( string shape, "script", string name, string &source);
evalScript(....);
Thanks.
Run script (event) of other shape
Re: Run script (event) of other shape
it is not possible to call a event of a shape from another script.
The QT events are only called when the user is interacting with the UI.
If a script shall be started based on another event normally the dpConnect() function is used. The work-function for the dpConnect() is called when one of the dp-elements defined at the dpConnect() are set.
If you need further information please descirbe exactly what you want to do.
Your question seems similiar to the question in this [url]topic: Event Execution[/url].
- vladimir
Thanks all.
