The SQL database contains a column defined as float.
Using PVSS 3.8 I retrieve these database values using a query. The data returned from the database is now captured in the form of a string, which isn't a problem.
However, within this string all decimal points are replaced by comma's.
The regional format of the Windows Server 2003 OS is set to English (United States), which uses a decimal point.
Does anyone has a solution to retrieve the data with decimal points? As it is now, I replace all comma's by points, but this isn't a neat solution.
Thanks in advance!
SQL database returns a comma in a float, instead of the expected decimal point
- ArdMolenaar
- fmulder
Re: SQL database returns a comma in a float, instead of the expected decimal point
Ard,
You're probably using WinCc OA scripting commands to retrievbe the data from the database. Isn't the float just returned as a float. Where is the float transformed into a string.
Can you attach the script that you use ?
- ArdMolenaar
Dear Frenk Mulder,
Thanks for the reply, I'm sorry for the delayed response.
I attached the script.
The function you will see returns the result from the SQL database in dyn_string &vResult.
This result is obtained by setting a datapoint which controls the SQLViaDP manager. This manager is from PVSS and it is a black box. I think this manager causes the problem.
Jeroen https://www.winccoa.com/fileadmin/image ... swerDS.ctl
- Attachments
[The extension ctl has been deactivated and can no longer be displayed.]
- fmulder
There is good news and bad news. I'm the original author of the SqlViadp manager. Unfortunately, since I left ETM 3 years ago, I do not have the C++ code of the manager and can't tell you exactly how the data is retrieved from MS-SQL.
I'd assume that there is some kind of for-next loop in the C++ manager that will eventually transofrm the data into a string.
There can be 2 places where the problem happens (Note: this used to work before)
a) The data is somehow returned differently by MS-SQL
b) The data is wrongly formatted by the SqlViaDp( which is weird because it used to work earlier)
You could try to use sprintf() in a standard PVSS script to see if there is soemthing wrong in the formatting of a float ?
It is hard to help without source. I could give you the folliowing tips:
1) ask Gertjan van schijndel at Siemens. He'll have the source code and this might help you to find out how the raw value from MS-SQL is transformed into a string.
2) You might change the query and 'ask' MS-SQL to return your float value in a different value (e.g. let MS-SQL format it into a string)
(See http://msdn.microsoft.com/en-us/library/ms187928.aspx )
Good luck !
Frenk
Good luck !
Frenk
- ArdMolenaar
What a coincidence, Frenk!
I am going to carry out your suggested tips. I will keep you up to date on this matter.
Thank you for the information.
Jeroen
Jeroen
- fmulder
That is weird...... that Ard suddenly signs his reactions as jeroen ?
Well good luck. I'd say that converting the value directly in the query should be the easiest and fastest solution
Good luck !
Frenk
Good luck !
Frenk
- ArdMolenaar
I'm new on the project and using Ard's account to get some support.
Ard sends his regards, though!
