Is there any difference (in terms of performance) between
a. Calling dpConnect() in a loop 100 times to connect to 100 DPs
b. Calling dpConnect() with a list of 100 DPs ?
For eg: calling dpConnect to display read-back value of 100 power supplies in a table, which method will be more efficient ?
dpConnect in a loop
Re: dpConnect in a loop
the difference between these two methods is the amount of data passed to the work-function if values change.
If you use a dpConnect with a list of dp-elements you'll get in every work function the complete list of dp-elements with their current values, even if only one dp-element is changed.
If you do dpConnects with only one dp-element you'll get only one dp-element and its value in the work function, when this value is changed.
- aorange
From my experience it seems more efficient to make 1 dpConnect with 100 DPE's than to call the same function 100 times with only 1 DPE. Same applies to a dpGet() and dpSet().
