Capturing SIGTERM and SIGKILL events in control script.
bhavna
Post by bhavna »
Is there any way to capture SIGTERM or SIGKILL events in control script? This is required, so that the control script can release resources ( in my case close a COM port handle) before the control manager running the script is closed.
Re: Capturing SIGTERM and SIGKILL events in control script.
there is no possibility to start a specific function when the process receives the signal SIGTERM. If SIGTERM is send the manager stops in a proper way.
SIGKILL will terminate the process immediately.
ragrawal
Post by ragrawal »
Can you suggest any other way to release the resources acquired by a control script in case it terminates / or terminated by closing the control manager from the PVSS console?
Our problem is that we have written a control script which communicates on the serial port and when the control manager is killed, the port handle is not released and any next run or any other application is not able to open the serial port.
Thanks and regards
Rajesh
On a Linux/Unix system, the kernel (!) is responsible for freeing resources a process has allocated and it also handles the closing of files (e.g. serial ports) a process has opened.
Probably you started some sub-process from the ctrl script which inherits the open file descriptors ?
Note: SIGKILL (aka kill -9) can not be caught by a process (see" man 7 signal": The signals SIGKILL and SIGSTOP cannot be caught, blocked, or ignored.)
ragrawal
Post by ragrawal »
Thanks for the reply ...
I am working on a windows machine. Pl. suggest.
regards,
Rajesh
With a control extension you might be able to get the SIGTERM and release your resources.
But it might be easier to place the control code in a panel and use the terminate event to release your resources. When you use the '-silentMode' option it does not require an ui license.
