How to export data from table in excel format?
BenjaminSeeker
Post by BenjaminSeeker »
Now I have export data from a table in excel format! but I can only export data in text file. It's there another way.
Here is my export ctrl:
main()
string timeS;
timeS = year(getCurrentTime())+"-"+month(getCurrentTime())+"-"+day(getCurrentTime())+" "+hour(getCurrentTime())+" "+minute(getCurrentTime())+" "+second(getCurrentTime());
TABLE1.writeToFile("D:/" + timeS + " ErreZhengqi.CSV", TABLE_WRITE_ALL_COLUMNS | TABLE_WRITE_COLUMN_HEADER , "; ");
system("explorer.exe D:\\\\");
aorange
Re: How to export data from table in excel format?
Post by aorange »
It is possible to write data to Excel using ComObjects but it isn't the most straight forward thing in the world, check out the createComObject() example in the help file to get started. I'll see if I can find a real-life example in one of my old projects to help you out.
One thing to be mindful of (which was the case in 3.10 at least) is that the CTRL and UI managers have different implementations of COM which can make it tricky if you write and test all your functions using a UI and then want to move them to a CRTL manager.
aorange
Post by aorange »
Can't find a good example of how to write to an Excel file but here is one on how to read from one, some things could have been done a little better but this was written a long time ago so bear with me ;)
int ReadExcelFile(string strFileName, dyn_dyn_anytype &ddaFileContent)
// Extract the complete content of the Excel file requested in the first parameter
// using the COM application interface provided by MS.
// Returns the file content in a dyn_dyn_any_type.
// Arguments required are:
// - strFileName, full path of the file to be extracted
// - ddaFileContent, a dyn_dyn_anytype variable to receive the information
  if(isfile(strFileName))
    dyn_string dsXlCol;
    dsXlCol[1]  = "A";
    dsXlCol[2]  = "B";
    dsXlCol[3]  = "C";
    dsXlCol[4]  = "D";
    dsXlCol[5]  = "E";
    dsXlCol[6]  = "F";
    dsXlCol[7]  = "G";
    dsXlCol[8]  = "H";
    dsXlCol[9]  = "I";
    dsXlCol[10] = "J";
    dsXlCol[11] = "K";
    dsXlCol[12] = "L";
    dsXlCol[13] = "M";
    dsXlCol[14] = "N";
    dsXlCol[15] = "O";
    dsXlCol[16] = "P";
    dsXlCol[17] = "Q";
    dsXlCol[18] = "R";
    dsXlCol[19] = "S";
    dsXlCol[20] = "T";
    dsXlCol[21] = "U";
    dsXlCol[22] = "V";
    dsXlCol[23] = "W";
    dsXlCol[24] = "X";
    dsXlCol[25] = "Y";
    dsXlCol[26] = "Z";
    idispatch xl;
    idispatch xlWorkbooks;
    idispatch xlWorkbook;
    idispatch xlWorkSheets;
    idispatch xlWorksheet;
    idispatch xlRange;
    anytype     aRaw;
    dyn_string  dsTimeStamps;
    dyn_float   dfVals;
    int intRows;
    int intColumns;
    /* Open Excel Object */
    xl = createComObject("Excel.Application");   // Create the application interface
    if(xl != 0)
      xl.visible   = FALSE;                                  // Keep the file hidden from the user
      xlWorkbooks  = xl.Workbooks;                           // Get the Workbooks collection
      xlWorkbook   = xlWorkbooks.Open(strFileName);          // Call the open event (inherited from the WorkbookEvents_Event)
      xlWorkSheets = xl.Worksheets;                          // Get the Worksheets collection
      xlWorksheet  = xlWorkSheets.Item(1);                   // Item is a property inherited from Sheets
      xlRange      = xlWorksheet.UsedRange;
      intRows      = xlRange.Rows.Count;                     // Get the number of used rows
      intColumns   = xlRange.Columns.Count;                  // Get the number of used columns
      for(int i = 1; i
BenjaminSeeker
Now I have another idea.
The ASCII manager can export DPE info into a .dpl file.
Then the .dpl file can be opened by Excel.
So I think maybe I can use the script to export the table data into a .csv file.
I think it will work.
So I will try it later.
aorange
Post by aorange »
I suppose it depends on what kind of data you want to export, if its DP/DPE parameterisation, etc. then I'd use the ASCII manager. If, on the other hand, it is process data you want to be able to recursively manipulate in Excel then I would use the method above.
If you only need to export process data as a one off then I would look at using something like Labour Values or Correction Values and manually copy/paste data into a spreadsheet.
