Unit level tests automation using framework in WCCOA API manager
santhosh.hiremath@siemens.com
Post by santhosh.hiremath@siemens.com »
We have been using WCCOA 3.11 version, With business logic written in API manager having asynchronous callbacks.
In an attempt to automate unit level test cases i tried frameworks like "gtest" and "gmock" but did not find it useful as
they do not provide option of mocking sequence of events in asynchronous way.
on searching through internet I came across SMI++ unit level test framework which supports mocking of sequence of events.
Is SMI++ compatiable with WCCOA 3.11 API managers ? Is there any other better unit level test automation framework that is compatiable
with WCCOA API managers ? which unit level test automation framework does etm make use for API manager unit level testing ?
Thanks in advance.
Santhosh Hiremath
paul.r.thompson
Re: Unit level tests automation using framework in WCCOA API manager
Post by paul.r.thompson »
I'm bumping this thread because I am interested in any unit testing processes/strategies. Not necessarily SMI++. It's pretty clear to me that gtest won't work, even if I intentionally separated logic from CTRL-specific functionality because the data types just don't map up perfectly.
I had thought of possibly writing an unit test support library - providing assert statements and such. Has anybody done that?
-Paul
