vogler
Posts: 122 Joined: Thu Oct 28, 2010 8:32 am
WinCC OA on Raspberry PI...
Post
by vogler » Thu Nov 28, 2013 8:57 pm
i got an unofficial WinCC OA version for the Rasp!
it runs damn cool...
http://www.rocworks.at/wordpress/wincc- ... pberry-pi/
root@raspberry1:~# uname -a
Linux raspberry1 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013
armv6l GNU/Linux
root@raspberry1:~# ps -ef | grep -i WCCOA
root 3677 3131 24 19:11 ? 00:25:34 /opt/WinCC_OA/3.11/bin/WCCOActrl -PROJ smh -pmonIndex 1 -num 6 Arduino.ctl
root 3683 3131 2 19:11 ? 00:02:40 /opt/WinCC_OA/3.11/bin/WCCOActrl -PROJ smh -pmonIndex 2 -num 7 SMAImport.ctl
root 5239 4887 0 20:56 pts/0 00:00:00 grep -i WCCOA
root@raspberry1:~#
blange
Posts: 8 Joined: Fri Nov 05, 2010 9:52 am
Re: WinCC OA on Raspberry PI...
Post
by blange » Fri Nov 29, 2013 2:26 pm
B) Hi Andi,
Quite cool, I have it also installed on my Raspi, running a bit slow but Raspi isn't a rocket
Most things run, but not Ultralightclientserver.ctl (not expected) . Started to integrate WIFI lamps with UDP control first.
will drain you knowledge and barrels at X-mas Party
CU Bernd
Posts: 634 Joined: Mon Aug 02, 2010 10:37 am
Post
by Gertjan van Schijndel » Fri Dec 06, 2013 12:31 pm
Is there also a 3.12 version for the raspberry pi?
Did somebody make a driver for the GPIO?
Posts: 741 Joined: Fri Sep 17, 2010 9:03 am
Post
by mkoller » Fri Dec 06, 2013 7:59 pm
Not yet .. I'll do it soon.
Regarding GPIO: no driver has been done. I use the GPIO pins just for output and do it with system() calls.
I'll attach my script I use to drive my garden watering valves.
https://www.winccoa.com/fileadmin/image ... les/pi.ctl
main()
// setup periphery
// GPIO for Outputs
system("echo 4 > /sys/class/gpio/export");
system("echo 17 > /sys/class/gpio/export");
system("echo 27 > /sys/class/gpio/export");
system("echo 22 > /sys/class/gpio/export");
system("echo 10 > /sys/class/gpio/export");
system("echo 9 > /sys/class/gpio/export");
system("echo 11 > /sys/class/gpio/export");
system("echo 7 > /sys/class/gpio/export");
// GPIO for Inputs
system("echo 8 > /sys/class/gpio/export");
// define outputs
system("echo out > /sys/class/gpio/gpio4/direction");
system("echo out > /sys/class/gpio/gpio17/direction");
system("echo out > /sys/class/gpio/gpio27/direction");
system("echo out > /sys/class/gpio/gpio22/direction");
system("echo out > /sys/class/gpio/gpio10/direction");
system("echo out > /sys/class/gpio/gpio9/direction");
system("echo out > /sys/class/gpio/gpio11/direction");
system("echo out > /sys/class/gpio/gpio7/direction");
// define inputs
system("echo in > /sys/class/gpio/gpio8/direction");
dpConnectUserData("work", "4", "Hauptregner.");
dpConnectUserData("work", "17", "Böschung.");
dpConnectUserData("work", "27", "Versenkregner.");
dpConnectUserData("work", "22", "Tropf.");
work(string num, string dpe, bool value)
system("echo " + (value ? "1" : "0") + " > /sys/class/gpio/gpio" + num + "/value");
[The extension ctl has been deactivated and can no longer be displayed.]
marcel@realsolutions.nu
Posts: 12 Joined: Mon Aug 02, 2010 10:22 am
Post
by marcel@realsolutions.nu » Sat Jan 25, 2014 12:30 pm
Since last month also running WinCC-OA on Pi, works great.
Last week received an IO board that supports control over SNMP and get it up and running: so the WinCC-OA SNMP driver on the PI controls a relais on the IO-board when an DPE is set
Next step was to get UltraLightClient running. The script is running on Pi, also the XML panels seems to be parsed when I request a panel in my Chrome browser, but the click-scripts of the pushbuttons are not working. Chrome reports this error (on load of the page):
"GET
http://192.168.1.66/data/http/libs/SVGkeypressed.js 404 (Not Found)"
Anybody got the UltraLightClient already running? with control of DPE's?
martijn.goedhart@croonwolterendros.nl
Posts: 5 Joined: Tue Sep 21, 2010 1:39 pm
Post
by martijn.goedhart@croonwolterendros.nl » Fri Aug 29, 2014 11:19 pm
Hi you all,
Any way for a WinCC OA enthusiast to get a copy as well, or is it limited to ETM employees only??
lukas.schopp
Posts: 39 Joined: Wed Nov 03, 2010 2:40 pm
Post
by lukas.schopp » Fri Aug 29, 2014 11:40 pm
Yes that's possible.
Write an e-mail to your key account manager or the support.
They will clarify.
Best wishes
Lukas Schopp
WinCC OA Product Manager
