Read & Write Excel-Files (*.xlsx)
beckj
Post by beckj »
I'm trying to to get a ADO connection to an Excel-File for read and write. With the example in the online help not even the connection to Access works.
Who can help me?
I'm using a 64 bit Windows 7 with 64 bit WinCC OA 3.11 SP1. Microsoft Office 2010 is 32 bit version.
I have added CtrlDLL = "CtrlADO" in the [ctrl] and [ui] sections.
I added the code from the example to the click event of a push button.
All I get is the following debug msg generated with dbGetError. Code means "Unspecified error"
[dbConnection "73D4DC8"][1][-2147467259][0]["[Microsoft][ODBC Driver Manager] Der Datenquellenname wurde nicht gefunden, und es wurde kein Standardtreiber angegeben"]["IM002"]
Re: Read & Write Excel-Files (*.xlsx)
I do not think you can use the 32 bit version of microsoft office with 64 bit WinCC OA.
Did you also try it with 32 bit WinCC OA?
beckj
Post by beckj »
I have to use 64 Bit WinCC OA. Microsoft itself recommends to use 32 Bit Office.
If that doesn't work together I have a serious problem!
And if nobody ever has read and/or written Excel files, I'll never get any advice.
So I'll have to go with CSV-files, which is ways too weak compared with Excel.
vogler
Post by vogler »
try to configure your odbc-connection with C:/Windows/SysWOW64/odbcad32.exe ...
brgds.
Andy
vogler
Post by vogler »
or maybe you can try to install a 64bit odbc driver
http://www.microsoft.com/en-us/download ... x?id=13255
