Severe problem with Archive when starting WinCC
schoenmakers
Post by schoenmakers »
when I start WinCC (3.10, on a Linux system) I get the following error:
PVSS00valarch(2), 2013.08.07 21:45:32.819, IMPL, SEVERE, 54, Unexpected state, Ar#2: Can't retrieve the start time of next set after set 5028 during reading dynamic header , [Archive.cpp:522]
PVSS00valarch(2), 2013.08.07 21:45:32.819, IMPL, SEVERE, 54, Unexpected state, Can't open archive (ErrNum=1), Reading from archiv header failed, [Archive.cpp:251]
PVSS00valarch(2), 2013.08.07 21:45:32.820, IMPL, SEVERE, 54, Unexpected state, Couldn't initialize archive instance... terminating!, [ArchivWrapper.cpp:1044]
I cannot start the para tool to investigate the archive, so I'm a bit lost to what I can do. Perhaps I can try to remove the existing archive files (there may be file corruption) but which are the files to remove, then?
Any help appreciated!
Arno Schoenmakers
schoenmakers
Re: Severe problem with Archive when starting WinCC
Hi all,
the problem seems to be hardware after all; an extensive disk check showed bad sectors on the disk containing the archive files, so we better replace the disk first.
Cheers, Arno Schoenmakers
