Hi All,
Is it possible to show the DPE Alias instead of the DP Name in DP name column of the Alarm screen?
if yes, how?
Thank you in advance,
Ezio
Show DPE alias in alarm screen
Re: Show DPE alias in alarm screen
Did you look in the online help -> system management -> Diagnostics -> Alert and event panel -> column configuration?
You can add a column with the value of wincc oa function 'dpGetAlias'.
It is not possible to show the alias instead of the dp-name (if an alias is defined) in one column. You can add a new column for the alias.
To the show the alias at the AEScreen you have to perform the following steps:
-- open the panel for the system management
-- select the tab "Settings"
-- open the panel for the "A&E - Row/Screen" configuration
-- select the tab "Alerts"
-- add a new column
-- for "Value" select "WinCC OA functions" and the Function "dpGetAlias"
-- save the settings
At the AEScreen you have to add the new column to the list of visible columns. If an alias is defined for every dp-element (with an _alert_hdl-config) you can remove the column for the dp-name from the list of visible columns.
-- add a new column
- olduser2343
Thank you Gertjan and Leopold,
Yes I did, but unfortunately, nothing happened, the new column just didn't show up in the AE panel.
So I also tried to tried to modify the existing column, whose function was "dpGetDescription". I replaced it with "dpGetAlias", but again, nothing changed.
Looks like the modifications I do in Column Configuration utilities are not propagated to the runtime system.
Ciao,
Ezio
Ciao,
Ezio
I've send you an additional mail for the official support request concerning this topic.
Please answer on this mail, then we can have a look at the problem in detail.
- Berry85
I have got the same problem creating a new column in the Alert Row/Screen. I already send Gertjan an email it's to bad there isn't an answer on the forum.
Greets berry
Greets berry
- fmulder
There's an x-file that descibes how to add an own column. Please look for the document.
Good luck
Good luck
the problem at the customers project was that the new column was not added to the list of visible columns in the AEScreen.
After making this modification it worked properly.
- Berry85
Thanks Gentleman,
I added a new Column to the A&E screen, the last thing what isn't changed is the infopanel in the top(or bottom) of the screen. I changed tease columns also in the settings tab, but there isn't a A&E Row configuration under the Diagnose tab.
I have searched of the X-files Frenk, but it is a lang ago that I have received them. Is the a place where the can be downloaded? Maybe this is also useful for other people using the portal
Greets Berry
Greets Berry
- fmulder
The X-Files can be found in the Lab section:
https://portal.etm.at/index.php?option= ... &Itemid=79
Good luck
Frenk
Good luck
Frenk
