I've just tried to install that Excel-Massedit Tool "MaPara" of PVSS.
Can anyone tell me, why it doesn't work in my case?
It says: "Compile error in hidden module: WB_MaPara. This error commonly occurs when code is incompatible with the version, platform, or architecture of this application. ..."
I'm using MS Excel 2010 on Win7 64Bit and WinCC OA 3.11.
Thank's!
Robert Nickel
MaPara won\'t work!
- aorange
Re: MaPara won\'t work!
I think this add-on was created for Excel 2003, are you sure it should work with Excel 2010?
there are known problems with the Excel-AddOn for the mass-configuration when using WinCC OA 3.11 as 64bit installation.
Please make the upgrade to 3.11+SP1.
Then the AddOn should work when using 32bit-version of Microsoft Office.
- robertnickel
thanks for the help.
MaPara seemed to work on other PCs of ours. But right now I'm not sure, if they had Office 2007 or 2010.
We wanted to upgrade to SP1 anyways so I'm gonna try that and we'll see.
Greetings,
Robert
Greetings,
Robert
