I have a WinCC server running on a windows machine.
Connecting to the wincc server with a winclient_http.ctl control works fine from windows machines,
but when I try it on a Linux machine (OpenSUSE 11.3), I get problems. The log on my linux box says
some libraries and/or scripts seem missing.
This is a very standard demo application, provided with 3.10SP1. So I must be doing something wrong.
What could it be?
Advice appreciated.
PVSS00ui (3), 2013.07.02 23:42:27.273, SYS, INFO, 39, Connection lost^M, MAN: (SYS: 1 Event -num 0 CONN: 1), Connection closed
PVSS00ui (3), 2013.07.02 23:42:27.282, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 1)
PVSS00ui (3), 2013.07.02 23:42:27.295, SYS, INFO, 39, Connection lost^M, MAN: (SYS: 1 Data -num 0 CONN: 1), Connection closed
PVSS00ui (3), 2013.07.02 23:42:27.321, SYS, INFO, 2, Manager Stop
PVSS00ui (0), 2013.07.03 00:15:10.393, SYS, INFO, 1, Manager Start^M, PROJ, DemoApplication_3.10, V 3.10 - not initialized
PVSS00ui (0), 2013.07.03 00:15:10.476, SYS, INFO, 3, Trying to connect to^M, (SYS: 1 Data -num 0 CONN: 1) @ localhost:4897
PVSS00ui (0), 2013.07.03 00:15:17.081, SYS, INFO, 4, Connected to^M, (SYS: 1 Data -num 0 CONN: 1) @ 172.16.246.131 (172.16.246.131
PVSS00ui (2), 2013.07.03 00:15:17.143, SYS, INFO, 6, Initialization by Data Manager finished
PVSS00ui (2), 2013.07.03 00:15:17.143, SYS, INFO, 3, Trying to connect to^M, (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
PVSS00ui (2), 2013.07.03 00:15:22.592, SYS, INFO, 4, Connected to^M, (SYS: 1 Event -num 0 CONN: 1) @ 172.16.246.131 (172.16.246.13
1)
PVSS00ui (2), 2013.07.03 00:15:22.631, SYS, INFO, 102, Waiting for user names/passwords
PVSS00ui (2), 2013.07.03 00:15:22.662, SYS, INFO, 103, User names/passwords initialized
PVSS00ui (2), 2013.07.03 00:15:23.620, SYS, WARNING, 133, Could not load shared library TabUtil^M, file not found
PVSS00ui (2), 2013.07.03 00:15:24.076, CTRL, WARNING, 117, Library defined as #uses "CtrlPv2Admin" does not exist. See script /home/hans
/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/pa.ctl
PVSS00ui (2), 2013.07.03 00:15:24.193, CTRL, WARNING, 117, Library defined as #uses "CtrlXml" does not exist. See script /home/hans/.win
PVSS00ui (2), 2013.07.03 00:15:24.533, CTRL, WARNING, 117, Library defined as #uses "CtrlRDBArchive" does not exist. See script /home/ha
ns/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/udag.ctl
PVSS00ui (2), 2013.07.03 00:15:24.650, CTRL, WARNING, 117, Library defined as #uses "CtrlRDBCompr" does not exist. See script /home/hans
PVSS00ui (2), 2013.07.03 00:15:24.656, CTRL, WARNING, 117, Library defined as #uses "CtrlPv2Admin" does not exist. See script /home/hans
/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/ptnavi.ctl
PVSS00ui (2), 2013.07.03 00:15:24.674, CTRL, WARNING, 117, Library defined as #uses "CtrlPv2Admin" does not exist. See script /home/hans
/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/userMan.ctl
PVSS00ui (2), 2013.07.03 00:15:24.679, SYS, SEVERE, 105, Invalid license^M, No License for the ctrl script maintenance (/home/hans/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/wh_sc.ctc)
PVSS00ui (2), 2013.07.03 00:15:25.152, CTRL, WARNING, 117, Library defined as #uses "CtrlCrypt" does not exist. See script /home/hans/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/login_internal.ctc
PVSS00ui (2), 2013.07.03 00:15:25.158, CTRL, WARNING, 72, Function not defined^M,
Module: Vision_4
Panel: vision/login.pnl []
Script: Initialize
Line: 15, paCfgReadValueDflt
PVSS00ui (2), 2013.07.03 00:15:25.158, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
PVSS00ui (2), 2013.07.03 00:15:25.158, CTRL, SEVERE, 72, Function not defined^M,
Module: Vision_4
Script: Initialize
Stacktrace:
1: main() at [Module: Vision_4 Panel: vision/login.pnl Script: Initialize]:15
PVSS00ui (2), 2013.07.03 00:15:31.675, CTRL, WARNING, 72, Function not defined^M,
Module: Vision_4
Object: 17 named: "cmdOK" of type: PUSH_BUTTON
Script: Clicked
Library: /home/hans/.wincc_oa-cache/DemoApplication_3.10/scripts/libs/userMan.ctl
Line: 823, paCfgReadValue
PVSS00ui (2), 2013.07.03 00:15:31.676, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
PVSS00ui (2), 2013.07.03 00:15:31.676, CTRL, SEVERE, 72, Function not defined^M,
Module: Vision_4
Script: Clicked
Stacktrace:
Module: Vision_4
Script: Clicked
Stacktrace:
1: umSetManagerPermission(unsigned uid = 0, unsigned area = 0, string displayHost = "linux-3ooq:0.0") at userMan.ctl:823
2: logincheck(bool bTriggerLoginOfUisOnComputer = FALSE) at login_internal.ctc:577
3: main() at [Module: Vision_4 Panel: vision/login.pnl Object: cmdOK Script: Clicked]:3
Winclient http 3.10SP1 - OpenSuse 11.3 - Problems
- hoesterholt
Re: Winclient http 3.10SP1 - OpenSuse 11.3 - Problems
You should manually copy the ctl-extentions from a linux installation to the 'PVSS_PATH/bin/linux' directory on the server.
Also the ewo's should be manually copied to the 'PVSS_PATH/bin/widgets/linux' directory on the server.
- hoesterholt
Thanks! BTW what are EWOs?
I'm new to the terminology.
EWO's can be found in the online help under 'Graphics editor (GEDI)' -> 'Complex graphics objects' -> 'EWO (External Widget Object)'.
It is basically comparable to activex, but can only be used for WinCC OA. And it can also be used under linux and solaris.
