Hi everyone,
I need to interact with OPC data—both reading from and writing to OPC UA servers. Could you explain in detail how to configure and implement this
I'm currently working on a project in WinCC OA version 3.20, and I need help with few things: 1. I want to write a control logic e.g., if a value exceeds a trigger an alarm or set another tag).
I need to bind a data point (tag)to a text field or slider in a panel. What's the recommended way to do this in version 3.20
wincc OA 3.20 version
- admin_01
Re: wincc OA 3.20 version
Hi everyone,
Information how to use the OPC UA client in WinCC OA you can find in the WinCC OA Documentation:
https://www.winccoa.com/documentation/W ... asics.html
For triggering alerts in WinCC OA you can use the _alert_hdl config. How to configure an _alert_hdl config is described in the WinCC OA Documentation:
https://www.winccoa.com/documentation/W ... RA-17.html
Interaction between data and the user interface is possible with objects and scripts in CONTROL (WinCC OA programming language).
https://www.winccoa.com/documentation/W ... _GEDI.html
We recommend to attend a basic training when starting to work with WinCC OA.
Information for the training modules you can find in the WinCC OA World:
https://www.winccoa.com/support/training.html
