I have juste a little question.
I am still developping my driver.
I want to write the driver status in a database.
How to write datapoint to database directly from address (without calling Resources::getId2Connect) ?
Thank you in advance for your answer.
Best regards
Yann
Write not Hardware configured dp from Driver
- CyaNn
Re: Write not Hardware configured dp from Driver
Well, I have found nothing in the Driver document I have to do what I want.
The idea seems simple : writing the status of the driver in an internal datapoint.
I am able to get the dpId of the point to write, but HWService::writeData only accept an HWObject.
I just want to be able to write a value in the database without any transformation.... just by simple query. What is the method to use for ?
For writing 'fixed' datapoints you should define the functions 'getNumberOfDpNames' and 'getDpName4Query' in your driver resources class to get your dpId's.
To get the dpId's dynamically you can use a 'NameServerSysMsg' message.
The retrieved dpId can then be used to do the usual Manager::dpSet.
- CyaNn
Thanks a lot Gertjan, it works greate.
I don't knew it was possible to use manager into a driver.
Thanks.
Best regards.
Yann
Thanks.
Best regards.
Yann
