acknowledge all active alerts
Mgiacome
Post by Mgiacome »
I'm trying to ack all active alerts relative to a DP, with control script, not with AES
So I get alerts with the following query
dpQuery ("SELECT '_alert_hdl.._act_state' FROM '"+dp+"*' WHERE '_alert_hdl.._class' == \"System1:alert.\" & '_alert_hdl.._act_state'==1 | '_alert_hdl.._class' == \"System1:alert.\" & '_alert_hdl.._act_state'==2 | '_alert_hdl.._class' == \"System1:alert.\" & '_alert_hdl.._act_state'==3 |'_alert_hdl.._class' == \"System1:alert.\" & '_alert_hdl.._act_state'==4", _alerts);
Then, in a for loop I check the alert state again with alertGet
// get state of alert. CAME unack, CAME ack, WENT unack, No alert
  alertGet(t, getACount(At), dpe+":_alert_hdl.._act_state", state);
  if ( (state==DPATTR_ALERTSTATE_APP_NOT_ACK) || (state==DPATTR_ALERTSTATE_DISAPP_NOT_ACK) ) {
    alertSetWait(t, getACount(At), dpe+":_alert_hdl.._ack_state", DPATTR_ACKTYPE_SINGLE); // single-acknowledge alert
  } else {
    DebugN("CANNOT Acknowledge Dpe state", dpe, state);
But the state I get with alertGet is different from the state got with dpQuery ! For example qith dpQuery I get ack_state 2 or 3, but with alertGet I get always act_state = 0
And also, if I skip the check of current state, system get me a SEVERE error
WCCOAui0:WCCOAui (4), 2024.12.06 08:41:41.704, PARAM,SEVERE, 23, Setting/modifying attributes failed, DP: System1:XXXXXX:_alert_hdl.._ack_state, MAN: (SYS: 1 Ui -num 4 CONN: 1), USER: 0
WCCOAui0:]
Do you have some suggestion ?
Ty
EDIT: corrected act_state.
Re: acknowledge all active alerts
Your description does not match the code parts. In the code you are reading _act_state and the description refers to _ack_state.
Which attribute are you talking about?
If you want to acknowledge an alert you must use the attribute _alert_hdl.._ack.
Please keep in mind the system names must not be used in a query string.
Mgiacome
Post by Mgiacome »
Sorry there was a typo.
I check act_state in order to understand if is possible to acknowledge that alert ( DPATTR_ALERTSTATE_APP_NOT_ACK or DPATTR_ALERTSTATE_DISAPP_NOT_ACK). Still get different values between dpQuery and alertGet
Have you tried to use the attribute _ack_possible to check if an alert can be acknowledged?
Maybe this attribute can be used to fulfil your requirements.
