Hi
I've noticed that dpConnect() keeps calling the callback function, even if the value of the input parameters do not change.
dpConnect("callbackFunction", dp1:_online.._value)
If I put a DebugN inside the callbackFunction, I keep seeing in the log that the function is called.
dp input parameters have an OPCUA subscription as pheriphery address. But their value don't change.
There's something I'm missing ?
Thank you
dpConnect keeps calling callback function
- kilianvp
Re: dpConnect keeps calling callback function
- gschijndel
Perhaps the same value is written multiple times. Are other attributes (like the timestamp) changing?
The "wantsAnswer" parameter only defines if the work function is triggered immediately when doing the dpConnect().
During runtime it has no effect if the parameter is set to to true/false.
- kilianvp
Oh, sorry. I misunderstood Mgiacome's problem.
- Mgiacome
Thanks all, the cause was the low level comparison setting unchecked inside the pheriphery address of the datapoint .... sorry
