Filter historical dpQuery
kdroog4pvss
Post by kdroog4pvss »
Setup:
WinCC OA 3.20 with SQLite and NGA influxDB
Legacy default project
I have tried to use the _AuditTrail datapoint to store entries in the archive.
The AuditTrail screen uses dpGetPeriod() to retrieve a period of data from the archive. The results are then filtered by script and presented in a table.
I tried to to something similar building a query:
string qry = "SELECT '.item:_original.._value', " +
               "'.newval:_original.._value', " +
               "'.oldval:_original.._value', " +
               "'.time:_original.._value' " +
               "FROM '*' WHERE _DPT = \"_AuditTrail\" AND  '.item:_original.._value' LIKE \"*.Bed*\" TIMERANGE(\"2024-08-08T11:02:49.000Z\",\"2024-08-08T17:24:12.000Z\",1,10)";
  dyn_dyn_anytype rs;
  dpQuery(qry, rs);
  DebugN(rs);
The result recordset appears to be filtered correctly, but the other values are empty. What am I missing here?. Is there any other way to let the NGA do the filtering instead of filtering the resultset? (Which is what happens in the AuditTrail panels).
WCCOAui1:[dyn_dyn_anytype 11 items
WCCOAui1:     1: dyn_anytype 5 items
WCCOAui1:	     1:  (Type: 0 Sys: 0 Dp: 0 El: 0 : 0..0)
WCCOAui1:	     2: .item:_original.._value (Type: 98 Sys: 0 Dp: 0 El: 6 : _original.._value)
WCCOAui1:	     3: .newval:_original.._value (Type: 98 Sys: 0 Dp: 0 El: 10 : _original.._value)
WCCOAui1:	     4: .oldval:_original.._value (Type: 98 Sys: 0 Dp: 0 El: 9 : _original.._value)
WCCOAui1:	     5: .time:_original.._value (Type: 98 Sys: 0 Dp: 0 El: 2 : _original.._value)
WCCOAui1:     2: dyn_anytype 5 items
WCCOAui1:	     1: HUT:_AuditTrail (Type: 98 Sys: 1 Dp: 273 El: 0 : 0..0)
WCCOAui1:	     2: "logButton01.BedieningType"
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     3: dyn_anytype 5 items
WCCOAui1:	     2: "logButton02.BedieningType"
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     4: dyn_anytype 5 items
WCCOAui1:	     2: "logButton03.BedieningType"
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     5: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     6: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     7: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     8: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:     9: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:    10: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:    11: dyn_anytype 5 items
WCCOAui1:	     3: -?-
WCCOAui1:	     4: -?-
WCCOAui1:	     5: -?-
WCCOAui1:]
hpuchegger
Re: Filter historical dpQuery
Post by hpuchegger »
Which WinCC OA version / patch are you using?
If the issue is related to pivoted queries - pivoted queries with a WHERE filter do not work conceptually (in no backend - either influx, PSQL, MSSQL, etc.)
As a workaround it is possible to this in CTRL: do the query with filter and without filter, then complete the filtered table with information from the unfiltered table.
Br, Herbert
kdroog4pvss
Hi Herbert, thanks for your answer. Currently we just changed from 3.19 to 3.20. The question however is not version specific I think.
I did not know about pivot queries until now 8-)
Since following query:
SELECT '.newval:_original.._value', '.newval:_original.._stime', '.oldval:_original.._value', '.oldval:_original.._stime' FROM '_AuditTrail' WHERE _DPT = "_AuditTrail" TIMERANGE("2024-07-21T18:35:18.000Z","2024-08-21T18:35:19.000Z",1,0)
returns a valid result. I did not understand why adding another where clause didn't responded as I suspected.
I will just query the timerange and process the result table by removing unwanted rows from it. That will work as well.
I have seen that in your first query you have been using the parameters "modus = 3" and "bonus = 10". At the TIMERANGE condition.
Please take into account that only modus = 1 is supported. All other values are there for compatibility reasons, they will use internally the value 1.
Normally when doing historical queries the _offline config is used instead of _original.
The hints are just common ones and not related to the query which did not work.
kdroog4pvss
Thanks, I have edited my post to avoid confusion on that part, just in case.
Kees
Possible there is an issue with the WHERE clause filtering for a DP element and an assigned value.
Please test your query without this specific WHERE condition.
