How to Copy Dashboard from one project to another project
deepaktony
Post by deepaktony »
Hi.
We have developed one WinCC OA Dashboard project for customer POC. Now, after approval from customer, we need to integrate/copy the same dashboard contents in to original running project of site. Is there any method or documents which describe the copy procedure?
Deepak PATEL
hpuchegger
Re: How to Copy Dashboard from one project to another project
Post by hpuchegger »
there is currently no document that describes a copying process in such a case.
To transfer dashboards to your target system, you can make an ASCII export of the data points contained in the internal data type _Dashboard. If you use customized widgets, you must also copy the dashboard folder from the directory.
After that, your dashboard content should also be usable elsewhere.
Br, Herbert
deepaktony
Thanks hpuchegger......Its working.....
