Our project DB does not work and seems like somehow wincc oa fails to create the "winccoa" database.
I had to run the influxd.exe manually first then when I check the influx.exe to see databases:
> show databases
name
_internal
when I try if it can use "winccoa"
> use winccoa
ERR. Database winccoa doesn't exist. Run SHOW DATABASES for a list of existing databases.
I restored the DB but it didnt work.
What would be the reason for sudden failure? It started appearing after a normal restart of the project.
winccoa database does not appear on influx
Re: winccoa database does not appear on influx
The Influx database is normally created when creating a new project if NGA is selected as archiving option.
During runtime or when stopping the project the database gets not deleted.
If you need further assistance for this issue please get in contact with your common WinCC OA support.
