Feature request: lock panel design
ahti
Post by ahti »
Hello!
The ability to lock panels to prevent mouse-initiated resizing and moving of objects in GEDI would make connecting parameters to objects and verifying correct assignments less stressful. Clicking around easily causes objects to be dragged out of place. A toolbar button labeled "Lock Panel" could be implemented for each panel, allowing users to toggle this feature on and off as needed. Thank you!
Ahti
name024
Re: Feature request
Post by name024 »
Hello Athi,
for this kind of work you can use the "Shape/Groupselektor" (Ansicht ==> Shape/Gruppenselektor) and select the Objects over the Table instead of select the Object in the View. Not exactly what you want, but maybe this helps?!?
Another cool thing would be the "#region"-Command (like in C# or Siemens SCL, etc.) in Control. This could improve the clarity/readablilty of large or medium size Control Code by example in Libarys.
