DpTreeView column width
tmalone
Post by tmalone »
I am using the DpTreeView widget to allow the user to pick a DPE for a development tool.
I have sized the DpTreeView object to 400 wide and high. But, the first column is still about half of that.
I studied the documentation very carefully, and just cannot find the property to change to expand that column.
Can someone tell me the magic: object.???(380)
Thanks,
Todd Malone
tmalone
Re: DpTreeView column width
Post by tmalone »
It appears to be a non-issue, as you select wider and wider structures, the column adjusts automatically to the widest record.
Auto adjust is fine for me.
Todd
rcampos
Post by rcampos »
Hi Todd,
I not sure if it is what you need, but you can try:
TREE_NAME.setColumnWidthMode(colIndex, TREE_WIDTH_FIXED);
TREE_NAME.setColumnWidth(colIndex, 380);
hope it helps you
