panel ref loaded on a tab in a tab widget - how to get tab widget name inside panel ref?
- tpjctrl
I have a tab widget on which tabs are created automatically based on dps existing. When a tab is created, it is loaded with a panel ref using the "namedRegisterPanel" function. Is there a way to get the name of the tab widget from within the panel ref that is loaded in the tab? I can pass the name of the tab widget as a $param when using the "namedRegisterPanel", but it's a but clunky and I'd rather avoid it if possible.
Re: panel ref loaded on a tab in a tab widget - how to get tab widget name inside panel ref?
I checked the documentation. It looks like there is no function available to get the name for the register from a panel loaded within a tab.
- gschijndel
