It would seem that the nuget packages for WinCC OA 3.19 Patch 6 are broken. The following nuget packages are installed:
etm.trace.1.0.2.nupkg
etm.wccoa.basics.1.0.2.nupkg
ETM.WCCOA.Interop.3.19.6.nupkg
ETM.WCCOA.Interop.3.19.6.snupkg
ETM.WCCOA.Manager.3.19.6.nupkg
ETM.WCCOA.Manager.3.19.6.snupkg
However the ETM.WCCOA.Manager.3.19.6 package has a dependency on ETM.WCCOA.Basics >= 1.2.0 which causes the package restore to fail. It also fails to properly install on a new project because of this missing dependency.
Does anyone else have this issue?
Packages for .NET API 3.19 P6 broken?
- gschijndel
Re: Packages for .NET API 3.19 P6 broken?
We have noticed this problem already with P005 and got the 1.2.0 version packages on the day of the P006 release.
- jcbaar
So does this mean that the packages will be included in the next patch?
- gschijndel
I assume so. Apparently it is recommended to use just Logging instead of ETM.Trace.
using ETM.WCCOA.Manager.Logging;
// configure logging
builder.ConfigureLogging(loggingBuilder => {
// add OA Logging Provider
loggingBuilder.AddOaLogFile();
// remove Console Logging Provider
loggingBuilder.RemoveConsole();
- hpuchegger
the correct packages will be available with the next WinCC OA version 3.19 P007.
However, if you need the correct files in the meantime, please open a service request so that we can provide you with the data promptly.
Br, Herbert
Br, Herbert
- jcbaar
@gschijndel
The out-of-the box .NET logging was one on the reasons I was trying to upgrade. I have currently a .NET logging provider based on ETM.Trace but wanted to use the logging provided in the new packages. I will wait for the correct packages to be released.
@ hpuchegger
I can wait for P007. No problem.
Thanks for the information.
@ hpuchegger
- jcbaar
I'm afraid the packages in 3.19 P9 are broken again. The ETM.WCCOA.Manager.3.19.9 package depends on ETM.WCCOA.Basics >= 1.3.0 but version 1.2.3 is installed with the patch. This is becoming a serious issue since managers compiled against the older packages do no longer work properly when P8 or P9 is installed
Sample error of a 3.19 P8 compiled manager running on a 3.19 P9 system:
WCCOAM_Archie(5), 2024.02.15 09:17:23.468, IMPL, SEVERE, 0, , WCCOAM_Archie ERROR: Processing EAD(Wait) failed. - One or more errors occurred. (Multiple errors during add of DPs (Unable to find an entry point named 'CSharp_ETMfWCCOAfInternal_DynVar_Append___' in DLL 'libCsCoreBridgeV319'.) (Unable to find an entry point named '?' in DLL 'libCsCoreBridgeV319'.))
