UI crashing after upgrading WOA 3.19 to patch 005
Tushar10ap
Post by Tushar10ap »
UI (vision and gedi) crashing after upgrading from 3.19 patch 004 to wincc oa version 3.19 patch 005.
after opening the script editor UI (Gedi) is crashing.
below is the log -
WCCOAui1:[0811/164751.811:ERROR:icu_util.cc(251)] Couldn't mmap icu data file
WCCILdataSQLite(0), 2023.08.11 16:47:53.213, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Ui -num 1 CONN: 1), Status code: Itc_Tp_Read_Call_Failed, errno: Connection reset by peer (10054)
WCCILevent (0), 2023.08.11 16:47:53.213, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Ui -num 1 CONN: 1), Status code: Itc_Tp_Read_Call_Failed, errno: Connection reset by peer (10054)
WCCOActrl (1), 2023.08.11 16:48:01.346, CTRL, INFO, 0, , Cyclic updateUserGroups running every 60 minutes.
your help will be appreciated. Thanks.
hpuchegger
Re: UI crashing after upgrading WOA 3.19 to patch 005
Post by hpuchegger »
This behavior is already known and our development is working for a solution. Specifically, the error occurs because the file "D:\Siemens\Automation\WinCC_OA\3.19\bin\resources\icudtl.dat" cannot be opened because it does not exist.
Can you please try to reinstall WinCC OA 3.19 P005 and see if it fixes the issue?
Br, Herbert
Tushar10ap
Thanks Herbert, for the reply.
I did complete uninstallation and then install patch 005, Its functionating properly now.
Br, Tushar
