Cannot define the Error Weight for MxProxy
fandersen
Post by fandersen »
Hi everyone,
I want to define the error weight for the MxProxy but I cannot see the manager type in the combo box.
We use: WinCC OA 3.17 P026
I get only the following options:
  • ControlManager
  • DeviceManager
  • DistManager
  • Driver
  • RedundancyManager
  • Archive
  • ApiManager
  • AsciiManager
  • DDEManager
  • Userinterface
  • OLE-DB
  • _Conn_redu_2_1_to_redu_2_2
Is there any solution?
https://pasteboard.co/qhwx9KxC7ZJ3.png
BR / Florian
fandersen
Re: Cannot define the Error Weight for MxProxy
Post by fandersen »
Maybe it makes no sense configure the error weight as the server-to-server communication won't work without MxProxy anyway.
Any thoughts?
If MxProxy goes down you loose access to all manager.
dbindernagel
Post by dbindernagel »
That is only true for managers on different hosts. Communication between managers on the same host does not go through the proxy.
For redu switches it probably does not make much sense to define an error weight to the proxy (might it switch faster?) but the feature allows more, for example to configure an alert on the manager going down. This is currently not possible.
You cannot configure an error weighting for the MxProxy as it is not connected to the Data- or Event-Manager as other managers in WinCC OA.
Therefore, in WinCC OA there is no connection information available and this is the cause why it cannot be configured.
fandersen
Post by fandersen »
OK, thanks everyone! It's clear now. ;)
