How to select shapes on a panel in runtime?
dbindernagel
Post by dbindernagel »
Dear all,
is there a way to select shapes / panel references on a panel in runtime via the mouse, like you would in the Gedi by drawing a border around the objects?
I know that a panel has the property "selection" [dyn_shape], but it seems you can only use it to manually store a list of shapes in there.
I need to be able to allow my users to easily select mutliple objects on my panel. I do have a working solution for this (by drawing&resizing a rectangle when the user clicks on the panel and calculating the shape insides the rectangle), but after seeing the "selection" property I'm not sure if there isn't already an in-built solution that I have overlooked.
Has anyone done this before?
What is the use case of the "selection" property?
Dennis
Re: How to select shapes on a panel in runtime?
I have tested it.
It looks like it works when the option "Runtime Selection" is set for a panel. For a graphical object the property "Selectable" must be set.
Then "selection" returns a shape list of selected objects. A multi selection is possible with the "Ctrl"-key.
gschijndel
Post by gschijndel »
Although it does not contain this selection property (yet), I guess it is part of the feature multiselection at run time
dbindernagel
Thanks alot Leopold Knipp and gschijndel!
This works like a charm.
Setting "Runtime Selection" to true on the process panels and then "Selectable" to true on the clickframe of my objects and I can select these by either drawing an rectangle around them or by clicking on them directly while holding CTRL.
Dennis
tpjctrl
Post by tpjctrl »
I'll tag along here and ask a related question.
Lets say I have a few rectangles on a panel, the panel has "Runtime Selection" enabled and each of the rectangles has "Selectable" set to true. I can get the list of selected rectangles using the "selection" method, but there's no event linked with selection on the panel level, so how do you "uiconnect" so that you can react to a user using their mouse to select rectangles?
