we are using WinCC OA V3.19 P003 on a Oracle Linux Server 9.2 system.
We want to create our initial database with WCCOAtoolCreateDb and datapoint lists during the creation of the database. Everything works so far, but we have the problem, with every creation of the database we are getting the default datapoint types with the corresponding datapoints (datapoint types ANALOG1, ANALOG2, BIT_CONDITION, COUNTER_SUB, COUNTER1, DRIVE1, DRIVE2, EXAMPLEDP_BarTrend, ExampleDP_Bit, ExampleDP_DDE, ExampleDP_Float, ExampleDP_Int, ExampleDP_Text, LABOR_ANALOG, LABOR_COUNTER, MODE_CMD, MODE_STATE, PUMP1, PUMP2, SETPOINT, SLIDE_VALVE_HAND1, SLIDE_VALVE1, SLIDE_VALVE2, SSC_KPI_Instance, WH_SC_SUB, WH_SC1).
These datapoint types/datapoints are of course not in our datapoint lists, which we are importing during WCCOAtoolCreateDb.
In the WinCC OA help I could not find any hint (https://www.winccoa.com/documentation/W ... olCreateDb). Using option -empty does not work (do not load internal datapoints).
This is our command to create the database and import the datapoint lists, which are listed in the file lists.txt:
/opt/WinCC_OA/3.19/bin/WCCOAtoolCreateDb -proj Projectname -importAscii /data/Projectname/restore/lists.txt -yesThank you in advance for your support.
