I would like to limit the size of an archive group to a limited number of values per DPE.
Has anyone already done this before? How did you do this?
Is this just with a database trigger removing the oldest records?
RDB/NGA limit the archive size to a number of values per DPE
- gschijndel
- hpuchegger
Re: RDB/NGA limit the archive size to a number of values per DPE
Which functions are available in the database regarding the segment duration depends on the type of database used, since databases can have different limits.
The size setting determines the archive group (which DPE is assigned to which archive) and is not defined via the segment (which you would like to do in this case).
Br Herbert
Br Herbert
- gschijndel
Thanks for the response, but it does not answer any of my questions
If this question is related to SR= 1-7083642375 or it is the same question please refer to the mails for the SR= 1-7083642375.
