Tree Widget - Parent Checkbox Functionality
emaddocks
Post by emaddocks »
The Tree widget provides the ability to add checkboxes to the items in the tree via the 'setCheckable' function. When this is set on the parent and child items in a tree the parent checkbox will check and uncheck the child items. This behaviour is fine if all the child items are enabled. However when one or more child items are disabled, via the 'setEnabled' function, the parent item still checks and unchecks the disabled child items even though they are disabled.
My expectation of this functionality is that the disabled child item should maintain it's state as it is disabled an the user can not click on it to change its state. However when the user clicks the parent they can change the state of the disabled child checkboxes.
Is this a bug or is this the intended functionality of checkboxes in the Tree widget?
Here is the code from the help file with checkboxes added to be able to demonstrate what I have described above:
main()
  //Add three columns
  TREE1.addColumn("SURNAME");
  TREE1.addColumn("FIRST NAME");
  TREE1.addColumn("ADDRESS");
  //Append the "WHOLE NAME" item
  TREE1.appendItemNC("","WHOLE NAME","WHOLE_NAME");
  //Append three sub items
  TREE1.appendItemNC("WHOLE NAME","MUELLER","Mueller");
  TREE1.appendItemNC("WHOLE NAME","SCHMIDT","Schmidt");
  TREE1.appendItemNC("WHOLE NAME","KAUFMANN",makeDynString("Kaufmann","Jan","Nebenstr. 100"));
  //Set the texts in the "FIRST NAME" column
  TREE1.setText("MUELLER", 1, "Maria");
  TREE1.setText("SCHMIDT", 1, "Anna");
  //Set the texts in the "ADDRESS" column
  TREE1.setText("MUELLER",2, "Hauptstr. 1");
  TREE1.setText("SCHMIDT",2, "Wienerstr. 10");
  //Append three subitems below the "MUELLER" item
  TREE1.appendItemNC("MUELLER","CHILDREN_M0","CHILDREN");
  TREE1.appendItemNC("MUELLER","CHILDREN_M1","");
  TREE1.appendItemNC("MUELLER","CHILDREN_M2","");
  // Set Checkable
  TREE1.setCheckable("MUELLER", TRUE);
  TREE1.setCheckable("CHILDREN_M0", TRUE);
  TREE1.setCheckable("CHILDREN_M1", TRUE);
  TREE1.setCheckable("CHILDREN_M2", TRUE);
  // Disable one child
  TREE1.setEnabled("CHILDREN_M1", FALSE);
  //Set the texts in the "FIRST NAME" column at the CHILDREN items
  TREE1.setText("CHILDREN_M1",1,"Klaus");
  TREE1.setText("CHILDREN_M2",1,"Anika");
Re: Tree Widget - Parent Checkbox Functionality
From my point of view, this is a bug, because the operator expects this. On the other hand, all other WinCC OA elements behave the same way. As a workaround, you can skip the setCheckable call for the deactivated item. Or check afterwards which items are deactivated.
