dialGauge styleSheet
tmalone
Post by tmalone »
I am using the dialGauge EWO object successfully. In my implementation, the object is small 60x60.
I would like to remove the needle shadow.
I can't find any reference to this object in the main stylesheet.css. I do see that there is a object styleSheet property, so I assume I can assign either a file or a formatted string to this?
Does anyone know how to remove the needle shadow using a stylesheet or other method?
Todd Malone
hpuchegger
Re: dialGauge styleSheet
Post by hpuchegger »
Dear tmalone,
I did not find a possibility to do that.
Br Herbert Puchegger
gschijndel
Post by gschijndel »
With a tool like GammaRay you could see that the widget has a property 'skin', but I guess that only built-in skins can be used.
It would be great if custom skins could be created and used. Then you would be able to create a skin without the needle shadow.
