WinCC OA 3.19 SQLite custom database
luis.bustamante
Post by luis.bustamante »
I'm using WinCC OA 3.19 P001 on Windows and Linux.
I would like to know if it would be possible to create a new database SQLite file manually inside the project, and to be able to connect to it from the WinCC OA CTRL code.
How could I connect to this new SQLite file from the OA code ?
Is there any functionality in OA 3.19 to directly access SQLite databases ?
Any help on this ?
Re: WinCC OA 3.19 SQLite custom database
In WinCC OA 3.19 you can use an SQLite database for storing the configuration of the data model and the current configuration/values. When this option is used the SQLite database is used instead of the RAIMA database.
If you want to access a database which is not directly related to the WinCC OA project you can use the OLE DB commands:
https://www.winccoa.com/documentation/W ... en-36.html
