user login statistics
An off-topic general discussion forum to chat about ANYTHING!
RKoczan
Post by RKoczan »
I'm trying to determine the last time a user logged into a system.
I tried the login statistics panel under SysMgm/diagnostics/ however I found that did not give accurate results. ie. many log ins were not shown.
Does anyone know of a way to the last time a particular user logged in other than by the 'login statistics' .
Thanks you
dbindernagel
Re: user login statistics
Post by dbindernagel »
The Login Statistics panels is just showing the archived data from the UserName element of the the _Ui datapoints.
Example: _Ui_1.UserName
If you are missing logins please check that the datapoint for the used Ui manager number has an active archive config.
Only the ones created during project creation have one already configured. If you manually add an _Ui datapoint you have to add the archive config as well.
If the element has an archive config then maybe the archives for the time range are already swapped out.
RKoczan
Post by RKoczan »
Thank you
