• Page 1 of 1
ja_ma_
Unit Test run from script
Postby ja_ma_ »
Is it possible to start all unit tests from a Control script?
I want to start all existing unit tests and check if any failed.
The possible options I have in mind so far:
1. In WinCC OA 3.19 you can start all unit tests by clicking on a folder and selecting "start all unit tests recursiv". Can I use this function in Control?
2. Starting every script file in the tests folder. For this i would need a control function, which justs needs the path to the file and then runs it E.g.: startScript("script path");
3. When creating a unit test file, it automatically creates a unit test class.
E.g.:
So far I was not able to use this class in other scripts, because the script can't find this unit test class.
Sounds like you didn't added TestFramework_3.19 as subproject.
I added the TestFramework and I am able to use the OaTest Library. But I am not able to tun the the TestClass (in this example "TstAdd") outside of the file.
