Passing a mapping by reference in CTRL [SOLVED]
fandersen
Post by fandersen »
Hi together,
is it possible to pass a reference to a variable of type "mapping" to a function?
I am currently investigating some script at our client. Some function checks that a mapping was asynchronously updated by a callback of a dpQueryConnectAll. The function evaluating the mapping never sees an update.
I have put together this example code doing basically the same as the real script.
The debug output is always "999", but I expect it to change to "123" after about 1 second.
mapping systems;
main()
  mapping m;
  systems["Test"] = m;
  systems["Test"]["value"] = 999;
  startThread("CheckMapping", systems["Test"]);
  delay(1,0);
  systems["Test"]["value"] = 123;
void CheckMapping(mapping m)
  while(true)
    delay(1,0);
    DebugTN("Check", m);
I have found the following Knowlege Base entry with an example, but it was not working for me. CTRL alway creates a deep copy of the passed variable.
How to avoid copy of string variables, mappings and dyn arrays at function call?
https://www.winccoa.com/knowledge-base/ ... -call.html
But changing the function "CheckMapping" to the following does not change the behaviour. CTRL still makes a deep copy of the mapping.
Or am I mistaken?
void CheckMapping(mapping &m)
  while(true)
    delay(1,0);
BR/Florian
dbindernagel
Re: Passing a mapping by reference in CTRL
Post by dbindernagel »
Passing a variable by reference is working. Check this code:
mapping systems;
main(mapping event)
  systems["Test"] = makeMapping();
  DebugN(systems);
  changeValue(123, systems["Test"]);
  // startThread("changeValue", 123, systems["Test"]);
  DebugN(systems);
void changeValue(string value, mapping &m)
  m["value"] = value;
The problem is that the thread is making a local copy of the variable that is not changed outside of the thread.
In , for example, C# you would have the same problem and might have to declare the variable as volatile.
https://learn.microsoft.com/en-us/dotne ... s/volatile
Not sure if there is a way to do this in CONTROL.
gschijndel
Post by gschijndel »
You could use a shared pointer to pass the variable to the thread
fandersen
Post by fandersen »
dbindernagel wrote: ↑ Wed Jan 25, 2023 1:16 pm The problem is that the thread is making a local copy of the variable that is not changed outside of the thread.
OK, I am glad that I've chosen this example as I spawn a new thread explicitly. In the real script, a callback (of dpQueryConnectAll) does the update of the mapping, which executes in a separate thread but it is not as visible in the code.
Now, I have changed the script to accesses the global variable directly and not pass it to the function as an argument anymore, which is working fine.
fandersen
Post by fandersen »
gschijndel wrote: ↑ Wed Jan 25, 2023 2:07 pm You could use a shared pointer to pass the variable to the thread
Yes, shared pointers work! Thank you!
mapping systems;
main()
  systems["Test"] = new mapping();
  shared_ptr<mapping> ptr = systems["Test"];
  startThread("CheckMapping", ptr);
  delay(1,0);
void CheckMapping(shared_ptr<mapping> mappingPtr)
  while(true)
    DebugTN("Check", mappingPtr);
    delay(1,0);
