Hi support,
What is the root cause of database error code-909 and what is be counted for dyntxtval.db transection?
To avoiding of this error
Winccoa 3.15
Spummalee
- Supachai.sp
- kilianvp
Re: What is the root cause of database error code-909 and what is be counted for dyntxtval.db transection?
https://www.winccoa.com/knowledge-base/ ... 4f1474aab8
To avoid an increasing size of the configuration history the time of the configs _alert_hdl and _alert_class can be set with dpSetTimed(0,...). All other configs do not have a configuration history, therefore a dpSetTimed(0,....); is not necessary and also not supported for these configs.
https://www.winccoa.com/documentation/W ... dpsettimed
The work around with using dpSetTimed(0,....); to avoid an increasing configuration history for the _alert_hdl and _alert_class config only helps if the configuration history is the cause for the database error/log message.
If other parts of the database are affected you have to check for other possibly causes.
