Alarm banner filtering can work on things like Short Sign and data type, none of which are runtime changeable. I found that you can filter on the "add_value" parts of an alarm instance. SO, it seems that you can script a change to one or more of the additional values that the banner can filter.
The documentation says that you can use only the alertSet() command. I have scripted it as it describes in the help, but the help is for ACK. I looked at other scripts in 3.18 ETM code, and I cannot find exactly how they script the add_value properties?
I have tried writing to the :_alert_hdl.?._add_value_20. The example code shows it always to a .?. number based on the alarm instance. That seems to work, but if you go back and try to update the value, the alertSet always reports setting/modifying attributes failed.
So, for the community... have any of you used these add_value attributes? Do you write to the :_alert_hdl.?._add_value_20 or the :_alert_hdl.._add_value_20 ??? I really need this feature to work, but I cannot seem to find a reliable way to update this.
Todd Malone
Trident Maritime Systems, LLC
alarm add_value
- tmalone
Re: alarm add_value
After some other research, I found in the help->system management->reports->SQL Query->Queries a reference the add_value
"SELECT ALERT '_alert_hdl.._add_value_5' FROM 'myAlarm.' WHERE '_alert_hdl.._add_value_5' == 1"
I guess this says that like the .._comment, that it is at the "root" of the alert instance.
Can anyone confirm this?
- gschijndel
Re: alarm add_value
Write should be done with the detail number from the atime of the alert.
Alert queries are always done without detail number.
- tmalone
Re: alarm add_value
I now have tried both ways. I have worked with other configs that are very picky about the number .?. like scaling. There is, without doubt, a difference in how they are handled, .. vs. .1. is different.
I will try to create a test screen and submit to ETM.
Todd
Todd
Re: alarm add_value
If you want to write a value to one of the _add_value attributes by using alertSet() you have to know exactly
-- The time of the alert
-- The count for the alert
-- The DP element for the alert
This information you can get with a dpQuery(). A dpQuery returns information as a variable type aTime. From the aTime you can get information by using the functions getAIdentifier() and getATime().
- tmalone
Re: alarm add_value
SOLVED.
If you change an add_value on an alert after the initial alarm, it changes the timestamp of the _online.._stime and _origional.._stime. If you try to change the _add_value later, the time will be wrong. Then, if you follow the help for alertSet():
dpGet(dpe+":_online.._stime", t);
At = makeATime(t, 0, dpe);
This time will NOT the time of the alert and the set update of _add_value will fail.
The correct way to get the time of the alert:
dpGet(sDPE + ":_alert_hdl.._act_state", iAlertState);
if(iAlertState != DPATTR_ALERTSTATE_NONE)
dpQuery("SELECT ALERT '_alert_hdl.._came_time' from '"+sDPE+"'", dda)
tCameTime = dda[2][3];
now you have a TIME type variable you can use to pass to
At = makeATime(tCameTime , 0, sDPE);
This will work for non-multi-instance alarms.
Code for multi-instance alarms is found here.
(help->PARA->data point configs, basics->alert handling, basics->Examples of alert handling).
- tmalone
Re: alarm add_value
Dear Leo,
Thanks for your insight, but it is not enough information. The help is lacking these examples.
"This information you can get with a dpQuery(). A dpQuery returns information as a variable type aTime. From the aTime you can get information by using the functions getAIdentifier() and getATime()."
All dpQuery return aTime types? maybe I need an example
I cannot search for or find getATime().
Why do I need the AIdentifier?
Can you give me a clue as to why you suggest a dpQuery but there are no examples for the elements you suggest time, count, element?
I really have spent days trying to understand this for both regular alerts and multi-instance alerts. The limitation of the alert banner filter to only add_values makes this feature critical to my efforts.
Todd
Todd
- tmalone
Re: alarm add_value
Follow on question.
I am writing to the _alert_hdl.._add_values using the alertSetWait function. My add_value_20 that I set does not stay like those set by the S7Plus driver? As the alarm changes from CAME to WENT and other changes like ACK, the add_value_20 value that I set is back to "" blank.
How can I set the add_value_20 so that it stays set for that instance of the alert like the values set by the driver initally?
Todd
Todd
- adaneau
Re: alarm add_value
Hey Todd,
As far as I know, you need to carry by script the add_values when the alarm status change. You can use a dedicated script for this or put it in the alert class scripts.
Alex
Alex
- tmalone
Re: alarm add_value
Alex,
Do we think that the driver also updates the add_values when the status changes? Or does the driver always set the add_values for each update from the driver?
multi-instance alarms are not easy to use at all.
Todd
Todd
