Is it possible to connect a WinCC OA 3.18 client with a WinCC OA 3.15 project running on a server.
Output from the Log Viewer:
WCCILpmon (1), 2022.10.11 10:36:37.008, SYS, INFO, 24/pmon, Got START command from ::1, starting the manager WCCOAui(1) at index 1
WCCILpmon (1), 2022.10.11 10:36:37.008, SYS, INFO, 1, Manager Start, C:\Siemens\Automation\WinCC_OA\3.18\bin\WCCOAui.exe -PROJ XXX -pmonIndex 1 -m vision -p vision/startup.pnl -iconBar -menuBar -stayOnTop -style none -num 1
WCCOAui (1), 2022.10.11 10:36:37.460, SYS, INFO, 1, Manager Start, PROJ,XXX, V 3.18 - 3.18 platform Windows AMD64 linked at Apr 30 2021 23:09:26 (91cfc2c6ff2)
WCCOAui (1), 2022.10.11 10:36:37.475, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ 10.2.13.21:4897
WCCOAui (1), 2022.10.11 10:36:39.509, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ SRV01 (10.2.13.21)
WCCOAui (1), 2022.10.11 10:37:00.536, SYS, INFO, 0, , Connection from SRV01 expired
WCCOAui (1), 2022.10.11 10:37:00.543, IMPL, FATAL, 5, Connection not possible, WCCILdata
WinCC OA 3.15 server connect with 3.18 client
Re: WinCC OA 3.15 server connect with 3.18 client
Within a WinCC OA system you must use the same version at the server and the client.
Even if it is technically possible to establish a connection between a client and server of different versions it is officially not supported and may cause unexpected behaviour, e.g. if the structure of datapoints (old version) does not fit functionality of the client (new version).
