SVG not working after Update
dbindernagel
Post by dbindernagel »
Hello All,
after upgrading my project a SVG graphic (as a background for a panel) is not working anymore.
Meaning it is not visible at all and the following error message appears in the log.
WCCOAui      (2), 2022.09.28 16:24:45.590, SYS,  WARNING,    54, Unexpected state, qt.svg, Invalid path data; path truncated.
The graphic itself can be opened without problems in other software (web browser, Inkscape, Libre Office Draw, etc.).
Old and new versions:
WinCC OA 3.18 P009 (= Qt 5.15.2)
WinCC OA 3.18 P012 (= Qt 5.15.8)
Google says that Qt had some problems with SVG graphics in the past already.
So my question is, if someone has an idea what I could do to "fix" my graphic so that this specific Qt version will accept it? (I'm not allowed to upload the graphic)
The graphic is quite big (~5MB) and even If I understood the format (which I don't) it is probably to big to manually fix it.
I tried opening it in a different software and saving it again, but this did not work.
Hope someone has an idea I could try.
Thanks in advance.
Dennis
Andorhal
Re: SVG not working after Update
Post by Andorhal »
Hello.
Seems to be a regression on Qt side:
https://bugreports.qt.io/browse/QTBUG-101698
We will integrate the mentioned 5.15.11 with the next patch and hope the issue will be gone.
Best regards.
dbindernagel
Thank You!
