AEScreen on Dist System
mathew.crothers
Post by mathew.crothers »
Anyone come across this problem before?
We have a dist system and setup DP groups for the AEScreen. However, due to the setup of our RTU's some of the DPs are cross systems inside the DP groups. Any group that has DPs cross systems will only show the alerts from System1 not both systems.
Tried everything in the filters but cannot get the AEScreen to show alerts from the two systems at once. Is this a limitation of WinCC OA AEScreen?
Re: AEScreen on Dist System
In a DP group you can also use DP elements of the own system. Using different systems in one group is not supported.
For details concerning DP groups please have a look at the WinCC OA Documentation:
https://www.winccoa.com/documentation/W ... ppen1.html
