_SumAlertPanel dpt changed recently?
tpjctrl
Post by tpjctrl »
I'm using some existing 3rd party code which works a lot with _SumAlertPanel dps and I've noticed that some of it doesn't work for distributed systems due to the way dpes are named within the _SumAlertPanel data point type:
Some dist systems show: Warning / Alarm / HighAlarm
Others show: Warning / Alert / Danger
We recently upgraded to 3.18 P011, was the _SumAlertPanel dpt changed in that patch to rename the dp elements?
Re: _SumAlertPanel dpt changed recently?
The structure of the _SumAlertPanel DP type is defined by the configuration of the panel topology. By default there are 3 ranges defined: Warning, Alert and Danger.
If you have a structure different to this one it was modified within the specific project.
