I am using clients with -ssa (server side authentication) in 3.18
We have requirements that some workstations cannot have a login with control (view only).
Is there a way to limit the logins on a workstation? or create a view only client?
FYI, I have looked at the LoginFramework and I do NOT want to invent my own security. Can I leverage this to check the login and stop anything but "guest"?
limiting login names on certain workstations
- tmalone
- tmalone
Re: limiting login names on certain workstations
I found this wonderful concept, "To open a desired panel after login" from the help. It is a parameter in the UI shortcut.
This works fine and I get my panel.
Once I have my panel, I then want to continue to the topology that I have setup. The help hints that you would use afterLogin("operator", "", "en_US.utf8") but that call just errors out with all sorts of "variable not defined". I guess this is not a function call for users?
How can I continue to open my topology after my special panel?
- tmalone
I tried to just used the function: setUserId(4096, "") on the init of the topology info panel, but it fails, probably because of -SSA
- tmalone
also tried using the auto-login features "-p vision/login.pnl,auto,$user:guest,$pwd: " and that fails with -ssa.
Is there a way to auto-login in SSA?
- tmalone
I have settled on a solution that seems to work. If the workstation is one of our read-only stations, we can check for the hostName on topology startup. If it is one of those stations, we run STD_LogoutCurrentUser() and disable the ability to click login buttons. NOTE: if you have to do this, you must put a delay(2,0) before the logout function to let the client finish initializing to avoid errors.
