Hello All,
Currently we are trying to implement TestFramework and integrate to our pipeline. However we are struggling to understand the usage from the help section. Is there any example projects that we can find and we can learn it through checking the example?
TestFramework 3.18 Example
- shokkul
Re: TestFramework 3.18 Example
Hello All,
I make it work somehow, the issue is descriptions are not clear and there is no example. In case you are stuck give all project id's test suite names id etc. same name so somehow it works. You just need to add the project that you want to test as a subproject in testRuns.[projName].config file.
