Module alignment in splitter
marco.van.aken@vanderlande.com
Post by marco.van.aken@vanderlande.com »
When adding a panel to a splitter module it is always left aligned.
Is it possible to change the alignment of a panel in a splitter?
gschijndel
Re: Module alignment in splitter
Post by gschijndel »
How would you like to have it aligned?
The only option there is to change the layout seems to be the layout direction.
If I don't use a splitter the panel is aligned in the center of the module. However when using a splitter (and two modules), the panel is left aligned in the module.
adaneau
Post by adaneau »
Hey,
Did you put a layout in the contained panels? If no, then you cannot guarantee the behavior of embedding them. This is pure luck then that it happens to be center for embedded and left for splitters.
I would advice to always layout embedded modules so you always control their look and feel.
