CTRL Debugger / UI
amichon
CTRL Debugger / UI
Post by amichon »
I'm using Version 3.18 P009
I'm trying to debug a panel it looks like the debugger doesn't display my panel until there's a panelref inside.
Also I put a pushbutton with a simple code in it and the pushbutton does not appear in the debugger.
Are there any precautions to take when using the debugger? I have the impression to do as before and it does not work the same anymore.
thank you all for your reactions
Aurélien
Re: CTRL Debugger / UI
I have tested it with a simple panel with just a few objects in it.
The CTRL debugger shows the objects which already have executed a script.
When you want to debug a "Clicked" script of a button it must be executed once before you can see it in the debugger.
amichon
Post by amichon »
Thanks a lot !
Looks like I've never needed to debug a clicked event until now !!
:D :D :D
