If I have changed some project's congif files while the project is working, I need to restrarting the project to apply the changing?
Changing in config files
- adaneau
Re: Changing in config files
Depends of the section. If you change in [data] or [event] yes you will have to restart. If you change for example in [iec] then you just need to restart your IEC drivers.
Alex
Alex
- MassEffect
Thank you for your answer!
I changed the [http] section in config file and the changed was applyed when I restarted the control manager with webclient_http.ctl
