In a panel that contains a web view I want to be able to use the default spell checking that is implemented in Chromium. In the Qt documentation there is a mention on how to enable spell checking (https://doc.qt.io/qt-5/qtwebengine-feat ... ellchecker) and an example (https://doc.qt.io/qt-5/qtwebengine-webe ... ample.html).
Is it possible to do this from WinCC OA? If it is possible how can this be done?
Also, to convert a dictionary to the format that Qt can read the "qwebengine_convert_dict" tool has to be used. Can this be done directly from WinCC OA or the Qt creator has to be installed?
How to enable spellcheck in a panel that has a web view?
- laura.petrisor
Re: How to enable spellcheck in a panel that has a web view?
I got the information that it is currently not possible in WinCC OA to enable the spellcheck.
